Old 14-Mar-2014, 4:25 AM   #13
Jec047
>> The DB4E + Y5713 is not overkill in your situation. In fact even larger antennas could be used.
The idea being that a bigger antenna requires less signal to acquire reception, yes?
But will the Y5713 do anything to solve my problem with channel 5?
Also, if I decide to mount more than one antenna, is there some minimum distance by which they should be separated?
Jec047 is offline   Reply With Quote
