Old 14-Mar-2014, 1:17 AM   #1
bobotech
Best type of antenna for using with a DVR like a TIVO
I am in the process of moving to a new location. The new location already has an antenna on the side of the home that is about 25 feet tall.
The issue I am having is that one of the main channels doesn't seem to come in but should. I am worried that I will have to put a rotor on the antenna to get that channel. That messes up the ability to use a DVR of some sort. I have a Tivo but I want to build a HTPC with a steaming feed device like the Silicondust HD Homerun device or maybe a dual internal ATSC tuner with XBMC.
If I have to use an antenna rotor, then I won't be able to reliably record using the DVR functions.
Are there any solutions? Can you use 2 antennas for the same feed? The main one for all the channels except for the one that doesn't come in and the other for the problem channel?
bobotech is offline   Reply With Quote
