Old 13-Mar-2014, 10:01 PM   #1
NGagne
New Member with questions
Good day Every one,
Frist, I would like to thanks Everyone for the support, I have been using the resource from that site for a long time.
So, I install my Home made Antenna with a reflecteur in the atic with a recycled balum, 50ft of coax, A wall plate, 6ft of coax, direct to the TV. (I use this site as Reference: http://www.tvantennaplans.com)
Right now I not sure what to do, I am receiving all the channel in Green and Yellow with the exeption of ABC (13) and FOX (43) (ABC is intermitent, I receive it form time to time)
http://www.tvfool.com/?option=com_wr...5b946b4bcec79a
MY LG TV is able to tell me the Percent of the Signal that it received 0 to 100%, I am having Good picture with 30% Signal and up. Unfortunately can't translate that to any DB reading.
Like I sad above ABC is intermittent the signal varies between 3% to 35%, So on good day I got picture and FOX is
1% to 15%.
I found out strange that I received Clearly every other station from Montpelier and not those two.
I am looking for option to get consistent signal for these two station. and not loosing all the other Also, I am not interested to in other Red or Gray Channel.
I don't want invest much for only 2 channel so any cheap solution are welcome.
I already try to re-aline my antenna; not much luck form that.
I have consider a 10 or 15db amplifier; Is it a good Idea?? and witch one should I Get??
Any other Idea ??
Thanks for the Support
Nicolas
NGagne is offline   Reply With Quote
