Old 13-Mar-2014, 9:54 PM   #1
ajia
Trying to cut through the BS
So I cut the cable quite a few years ago, then cut satellite about a year ago and went OTA.
I ended up purchasing a LAVA HD2605.
Mistake. Some channels come in, but not the range advertised (hence my title). Plus the motorized rotator does not hold the antenna steady in a breeze. Sometimes I find it pointing in a slightly different direction.
So here's the particulars, I live in Ventura, CA, 93001 by the coast.
I'd like to receive the LA stations for the major channels, but if possible also the local channels to the north (Santa Barbara, etc).
Here's my analysis:
http://www.tvfool.com/?option=com_wr...5b9420bbce5b8b
Though I am a bit skeptical because it shows the L.A. stations at 70 miles away as only needing "An indoor "set-top" antenna is probably sufficient to pick up these channels"
Any recommendations would be appreciated.
ajia is offline   Reply With Quote
