Old 13-Mar-2014, 7:34 PM   #3
Here some and not all build your own antenna web sites.
http://www.wtfda.org/mem/rhombictvants.pdf.
http://www.wtfda.org/mem/rhombic.pdf.
http://www.mapability.com/ei8ic/rhombic.php.
http://www.ccdxc.org/ant_calc.htm.
http://www.antennacraft.net.
Has the already built , Y5-2-6 , VHF channels low band 2 thru 6 antenna.
And it looks like , http://summitsource.com.
Has the , Winegard YA6260 , VHF channels low band 2 thru 6 antenna.
Antennas of the 3 Tv channel bands.
UHF band channels 14 thru 51.
can be connected with separator / joiners.
HLSJ = VHF high band / low band , separator / joiner.
UVSJ = UHF band / VHF high and low band , separator / joiner.
Reversed splitters;
Basic splitters have direct wire connections on the inside the splitter , this allows signal strength bleed off from one antenna to another antenna.
To limit signal strength bleed off use.
Use capacitor coupled splitter.
Or use micro strip line coupled splitter.
Antenna selection can be done with a A/B switch and combinations of A/B switches.
http://www.mcmelectronics.com.
Model , 32-4425
Or can use separate tuners connected to the separate antennas and to the Tv.
http://www.epvision.com
Last edited by teleview; 13-Mar-2014 at 9:53 PM. Reason: Clarify information and typos.
