Old 13-Mar-2014, 9:02 AM   #4
Thinking that Tv antennas are eye sore and ugly and hiding Tv antennas is a good way to have less reception.
--------------------------->Tv Antennas are Beautiful and Handsome.<-------------------------------
A small improvement of signal strength at 25 feet.
The Digital Broadcast Tv Stations/Channels are , weak signal strength and Very weak signal strength at your reception location.
KACY-DT , Real UHF channel 27 , virtual number (32.1) , MyNetwork.
Is Very weak signal strength , of 5.9 NM(dB) , with 2 Edge Path Obstructions= hills and mountains in the reception path , and is in the Red reception zone.
It is important to install the antenna Above the Peak of the Roof in such a manner that the reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of reception.
The Group of Digital Broadcast Tv Transmitters are to the South West.
Recommend install a , http://www.channelmasterstore.com.
CM4228HD UHF/VHF antenna aimed at about 230 degree magnetic compass direction.
Install a , http://www.antennacraft.net.
10G221 preamplifier.
Operate the 10G221 preamplifier in the single antenna mode.
Put the FM radio trap switch in the , in/on , position.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
http://www.hollandelectronics.com.
http://www.ronard.com.
Last edited by teleview; 13-Mar-2014 at 10:20 AM. Reason: Clarify information and typos.
