Old 12-Mar-2014, 7:29 AM   #2
I recommend , First , have Reliable Reception of the Many Digital Broadcast Tv Stations/Channels to the , South West , West , North West , North , East.
And then experiment with home made antennas and etc.
Install a , Antennas Direct , DB8e antenna Above The Peak Of The Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception.
Aim 1 panel at about 250 degree magnetic compass direction.
Aim the other panel at about 355 degree magnetic compass direction.
Buy the Antennas Direct DB8e antenna at , http://www.amazon.com.
Use a , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html .
Use a , ronard(4560) , eave antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com .
Install a , http://www.antennacraft.net.
10G201 preamplifier.
Buy the preamplifier at , AntennaCraft , or , http://www.amazon.com
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D and HFS-3D and HFS-4D , splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Go into the Tv Setup Menu and select and channel scan for ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
DO NOT select and channel scan for cable tv channels.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
The December 2013 issue of Consumer Reports , page 42 , has a Practical and Useful and Informative article about Internet Streaming Receivers and services such as and not limited to , Netflix and Hulu+ , etc. .
Last edited by teleview; 12-Mar-2014 at 8:48 PM. Reason: Clarify information and typos.
