Old 12-Mar-2014, 4:25 AM   #16
dmfdmf
KGO, real CH-7 & KNTV, real CH-12 are likely to suffer more reception problems with the Leaf due to the lack of an element designed for VHF reception.
KGO rebroadcasts out of Allison Mt in Fremont at RCH35 so it is possible OP could go with a flat UHF antenna and get everything but KNTV/RCH12. I am not sure what the signal is like in Alameda but on the West side of the bay I pickup both sources for KGO at RCH7 and RCH35.
Here is my recommendation if the OP can't go without NBC
http://www.winegard.com/freevision/
Its small and thin and it has holes in the main boom for nailing to a wall and does both UHF and VHF. I'd find a stud and nail it to the wall right behind the TV as high as you can go. Re-zero and rescan channels and see what you get. If you didn't want to look at it you could hang a drape on the wall behind the TV and hide this behind it, only 6" deep.
dmfdmf is offline   Reply With Quote
