Old 12-Mar-2014, 12:56 AM   #43
The CM3414 was still installed,was it not?
I'd like to see 100% stable reception of all your channels before committing to the additional expense of the AC7.
Can you re-run the individual antenna tests without the Holland splitter installed? IOW, one at a time, connect each antenna to the input of the CM3414 using the shortest possible cable run. How long would that cable be for each antenna?
What does the line of sight from the C2V look like on the signal path towards Fordland? Clear, a few trees, a lot of trees, houses, etc? I'm concerned that if reception isn't stable now and if there are trees, your reception ill fall off a cliff as soon as the trees leaf out.
