Old 11-Mar-2014, 8:48 PM   #2
The tvfool report is not showing any antenna height above ground.
Do not delete the tvfool report that is not showing any antenna height above ground.
To see if reception signal strengths improve with higher antenna height.
Please make and post a tvfool report with the antenna height at 25 feet above ground.
25 feet antenna height above ground is a Reference antenna height that provides a good evaluation of the Tv stations and channels that can be received.
