Old 11-Mar-2014, 8:34 PM   #11
dmfdmf
Originally Posted by stvcmty View Post
GroundUrMast's recommendation is the about as close to the best you will get indoors without putting an outdoor antenna inside your apartment.
The old aesthetic cost/benefit ratio, also called the wife factor :-)
Assuming the wall behind the TV is facing West (enough) and ugly is not too much of a factor relative to the desire to watch TV, you hang a two bay with VHF on the wall behind the TV, high up near the ceiling and probably get good signals that don't drop out when people move about.
http://www.solidsignal.com/pview.asp...tenna-(hd-1080)
You'd probably even get some of the signals from the East towers off the back of that antenna. If OP put this up and got great reception then after about a week or two you wouldn't even notice it.
dmfdmf is offline   Reply With Quote
