Old 11-Mar-2014, 5:39 PM   #6
You cannot install a standard splitter between a pre-amplifier and its power inserter. If you do so, you deprive the amplifier of the power it needs to operate and it turns into a brick.
You can use a splitter rated for satellite use that has diode steering internally. That way, you don't need any voltage blocks and you can power it from ANY outlet that has a direct connection to the splitter.
