Old 11-Mar-2014, 5:19 PM   #5
VeroWing
Thanks for the reply GroundUrMast. I've amended the location of the RCA TVPRAMP1R to just below the antenna. I also located the power supply feed to before the three way splitter, and now am seeing good results from the preamp unit(one of them). In order to do this I have to have the power supply transformer up in the attic to be pre splitter. Don't really like that idea, so as per some info I've dug up, I will add coaxial voltage Blocks out of three way splitter to two of the tvs, and then plug preamp power source at third tv location. How does that sound to you?
VeroWing is offline   Reply With Quote
