Old 11-Mar-2014, 12:06 PM   #40
Doesn't this mean the Holland 2FS is already being used as a "reverse splitter"?
Yes, it is.
If that is the case, should I still disconnect the coax from the antennas connected to the "output" of said splitter (one at a time) to check each antennas reception?
Yes, that's correct. If you have one, install a terminator cap on the port that you just removed the cable from.
