Old 11-Mar-2014, 9:42 AM   #2
The Philadelphia Area Digital Broadcast Tv Stations/Channels have the Most Networks to receive.
A antenna aimed at about 280 degree magnetic compass direction will receive Philadelphia Area Tv stations and some of the stronger New York Tv stations.
The Current Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has channels All 3 Tv Bands.
Install a ,
http://www.antennacraft.net.
HD1200 , All channel antenna Above The Peak Of The Roof aimed at about 280 degree magnetic compass direction.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence PIPE that is good for antenna mast pipe , the price is about 10 dollars.
I am not saying to use the full length of the pipe , what I am saying is , makes good antenna mast pipe and is low dollars.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , West , South West , North West , North , North East.
http://www.hollandelectronics.com.
http://www.ronard.com.
Last edited by teleview; 12-Mar-2014 at 12:39 AM. Reason: Clarify information and typos.
