Old 11-Mar-2014, 8:13 AM   #6
vt6364
Some udates
I setup a dipole antenna following dmfdmf's instruction and confirmed RCH4 is available. Didn't work at first, but after some adjustments and aim it instead of just south-wall mounted, I was able to see 4.1 and 4.2. It's interesting how precise the aiming & dimension must be for this rudimentary indoor setup to get a clear picture (even from a LOS source). Simply changing the T-length by about an inch would cause it to pixelate, and about 3” would lose reception all together.
Will get the popularly recommended ANT751 & a TVPRAMP1R, and try them out next weekend. Then will keep one antenna that works and return the other -assuming I won’t accidently drop it from the 2nd floor window, or trip and land myself on it during this many trials Will also try pointing the DB8e at other mountains for reflected signals as teleview suggest; I still have some 20 days to return it.
Yes I read about FCC rulings. Attic installation is still preferred, simply because it’s a lot easier. My house is facing N-NW, and we are in small lots on a hill side, with the house to my east higher than mine. To get east channels, the antenna better be in the frontal-most part of the house to avoid having to reach higher than east-neighbor’s roof, and I don’t like having an antenna in front of the house myself, regardless of whether the HOA cares. The only pocket of attic space I have is luckily in this front part of the house, but it’s tiny.
I have some more questions, coupled with some details I didn’t mention before:
- Is it detrimental to put antenna on a flat roof (asphalt shingle)? I have such an area of one-story roof in the back (the front part is 2-story with gable-end tiled roof). If I cannot get anything from the attic at all, I am thinking I’d build sort of a wood stand, attach it to the roof to hold the south-aiming antenna in proper orientation; still easier than erecting a mast. My south view is mostly clear looking down hill, no need to go high (the 40/40 and 13/13 channel towers are visible from my back window).
- After trying the DB8e outside my front window, I also tried pointing half of it at 80degT, and lost many channels. Did not record exactly which ones were lost though, just quickly concluded that I need a full DB8e, even for outdoor.
- I did try pointing the 2 halves of DB8e separately to 180degT and 80degT in the attic. But they were still right next to each other, both connected to the DB8e’s combiner. Results were pretty much the same as when they both pointing at either direction. This is probably due to reflected multipath, since I don’t see as many South channels when outdoor pointing 80degT (only the RCH40 and RCH28 I think). So the DB8e (and any reflective-disc style) is more prone to multipath than the Yagi-style 751?
To dmfdmf,
Do you still think it’s worth rigging up 2 DB4s (if the 751 doesn’t do)? There is very little space (that is >= 40” hi for the DB4s) in the attic, so they will not be more than maybe 2-3 Ft apart in there. I am curious how you modify it to improve VHF (at the cost of some UHF performance I assume?), but not sure I’d spend $160 on the DB8e to experiment. Is the mod reversible and I can still return it?
Thank you all. You folks are really amazing, not just because of your knowledge, but also for how you’d spend the time to read and answer people’s questions like this.
vt6364 is offline   Reply With Quote
