Old 11-Mar-2014, 7:16 AM   #5
For reception of the Tv stations in the Green and Yellow reception zones of both directions , North West and South East.
Install Above the Peak of the Roof a , Antennas Direct , DB8e antenna.
http://www.amazon.com.
Aim 1 panel at about 338 degree magnetic compass direction.
Aim the other panel at about 117 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas.
For 1 Tv connected a antenna system amplifier will most likely not be required.
Disconnect and remove satellite systems devices such as and not limited to , receivers , multi-switches , multi-plexers , connectors , splitters , amplifiers , power injector/power supplies.
Yes the satellite system coaxes and cable system coaxes can be used for the antenna system.
Any pay cable service such as and not limited to , cable tv service , cable internet service , cable phone service , Must Be on a Separate coax that is not connected to the coaxes that are used for the antenna system.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence PIPE that makes good antenna mast pipe and is low price at about 10 dollars.
I am not saying that you have to use the full length of the pipe , what I am saying is , works well as a antenna mast pipe and the cost is low dollars.
Here are some Digital Tuners and Digital Tuner Recorders.
http://www.epvision.com.
Walmart has a basic converter box , RCA DTA800B1 .
Last edited by teleview; 12-Mar-2014 at 1:13 AM. Reason: Clarify information and typos.
