To reduce problems with reception and distribution of the Tv antenna signals.
Disconnect and Remove All satellite devices , such as and not limited to , receivers , multi-plexers , couplers , combiners , splitters , amplifiers , power injectors/power supplies and etc. .
Yes is Ok to use the satellite system coaxes for the antenna system.
It is important to keep in mind that coaxes and connections can be defective even if the coaxes and connections look ok.
Test reception with 1 Tv connected , No splitter.
Then use a splitter to connect the other Tv's.
A Winegard LNA-100 Boost , antenna system amplifier can be installed before any splitters - if required - .
Notice that the word is - if - , not , will be .
Reason: Clarify information and typos.
