Old 10-Mar-2014, 10:23 PM   #1
oysterjetski
Antenna Advice For Mesa AZ
Hello everyone.
I need some advice on an antenna set up. First off, here is the signal report.
http://www.tvfool.com/?option=com_wr...5b9413e3413efb
It's a two story condo/town house set up. No exterior antenna allowed by the HOA so I have to install it in the attic. The home is pre-wired with RG-6. There will be only two Televisions hooked up to the cable run.
I've used a MOHU leaf amplified unit, and I could not get a good signal on all the channels from PHX.
It looks like the major network channels are on high VHF band. I've been thinking about one of these antennas; the Channel Master CM-2016 or CM-4221HD. Which of these would be better in my set up? Are there others that would work better?
Thanks for your time and help,
Mark
oysterjetski is offline   Reply With Quote
