The UVSJ isn't the right tool for this application. He's trying to merge a UHF 49 (KRBK) signal from the 91XG with a VHF 10 through UHF 44 signal group (everything else).
I would like to know if this is "phase cancellation" that has been referred to by ADTech and that the AC7 combinber is the solution to this issue before ordering.
It's likely that signals from the 91XG are interfering with the signals from the C2V. Until you go back and read post #28 and answer the questions posed there as accurately as possible, you will not have your best odds of understanding what you need. Otherwise, its mostly an educated guess or estimate.
