Old 10-Mar-2014, 8:26 PM   #33
mulliganman
Let me clarify. I have a Clearstream 2V aimed at approximately 50 degrees. I have an Antennas Direct 91XG aimed at 349 degrees (this antenna is picking up Fox KRBK). The signals are being combined using a regular Holland splitter, sent to the Channel Master 3410 distribution amp then splitting the signal to 3 TV's. What I have been noticing since adding the 91XG is a couple of channels are experiencing signal dropouts/pixelation that weren't doing so prior to adding that antenna. I would like to know if this is "phase cancellation" that has been referred to by ADTech and that the AC7 combinber is the solution to this issue before ordering.
