Subject: Antenna aiming.
Directional antennas such as and not limited to the HBU11/k antenna.
Receive the best in the forward direction.
A little less at front angles to the antenna.
Less at back angles to the antenna.
Less at the back of the antenna.
And receive the least amount of signal directly on the sides of the antenna.
Look at the Tvfool radar map for the Current Plus Pending Applications Included Tv Stations.
Your reception location is in the center of the circular radar map.
The Tv stations are all around.
Most of the Tv stations are Strong Signal Strength in the Green reception zone as shown on the circular radar plot and in the tvfool channel list.
Keeping in mind , the way directional antennas receive as described.
On the radar map I see a group of Tv stations to the South East that are not as strong of signal strength as the most of the other Tv stations of the other directions and appear to be Tv Networks that are not received in other directions.
So I recommended aim the antenna at the weaker Tv stations to the South East.
Aiming a directional antenna is a Balance Type of Situation to receive strong signal strength Tv stations and weak signal strength Tv stations.
And the Aim of the antenna Also takes in to account the Tv stations you will like to receive because the Tv stations have Networks that are of interest to you.
