Old 10-Mar-2014, 1:56 PM   #1
GLD
Any chance with indoor antenna? Located between NYC and Philly
Hey everyone.
I live in an apartment about halfway between NYC and Philly.
Unfortunately I'm not able to install an attic or roof-top antenna, so my only real option would be an indoor antenna of some sort. I live on the second (top) floor of the apartment, so the antenna will be ~15-18ft above ground level. The apartment window faces NE (in the other direction several walls will be in the way).
I'm not after every channel available - a couple of the main channels (out of ABC, CBS, NBC, PBS etc) would be sufficient (mainly just for nightly news).
Is there any chance that I might be able to achieve this in this location? If so, would anyone have any specific recommendations for an antenna type that would work? It seems like it may be a bit tough from the reception reports.
Would an amplified indoor antenna be the best option to try in this location?
Report link:
http://www.tvfool.com/?option=com_wr...5b94582fbb0d73
GLD is offline   Reply With Quote
