Old 10-Mar-2014, 7:39 AM   #6
Originally Posted by dmfdmf View Post
RCH7 is 174-180 MHz, have you tried an FM block? Run an FM Fool report for your location and see if you have any hot FM stations nearby broadcasting around 88 to 90MHz which could be interfering. As others have mentioned you are in a great spot for reception and the amp could be making things worse. Custom tuned antenna is a good idea to see if you can get anything....
Why didn't I think of that?
