Old 10-Mar-2014, 5:59 AM   #2
The Tvfool Radar Plot and Channel List of the Digital Current Plus Pending Applications Included.
The Tv stations in the Red reception zone will not be received with a antenna in the attic.
Some of the stronger signal strength Tv stations in the Yellow reception zone might be received reliably in the attic.
The Tv stations in the Green reception zone will most likely be received reliably in the attic.
If you will like to receive the Tv stations in the Red reception zone and the weaker Tv stations in the Yellow reception zone.
A LARGE antenna installed Above The Peak Of The Roof is Required.
I recommend , http://www.antennacraft.net.
HBU55 antenna.
