Old 10-Mar-2014, 5:22 AM   #2
Many Digital Broadcast Tv Stations/Channels will be received.
It Is important to avoid aiming the antenna in to close thick trees and tree leaves.
The more distance the trees are from the antenna in the direction of reception the better for reception.
Select a location that has the least amount to no amount of trees and tree leaves in the direction of North West and South East.
For reception of the , Evansville , Henderson , Owensboro , Area Digital Broadcast Tv Stations/Channels.
Install a , http://www.antennacraft.net.
HBU55 antenna aimed at about , 324 degree magnetic compass direction.
Install a , http://www.antennacraft.net ,.
10G201 preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence PIPE that makes good antenna mast pipe. The price is about 10 dollars.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Channel Scan for the , Antenna Channels , Air Channels , ATSC-Digital Broadcast Tv Stations/Channels.
