Old 10-Mar-2014, 4:33 AM   #3
The signal strengths are Strong Signal Strengths at your location.
---->DO NOT use any type or kind of signal amplifier.<----
---->Not built in to the antenna , Not external to the antenna , Not a preamplifier , Not a distribution amplifier , No type or kind of antenna system amplifier.<----
Install a.
ANT751 antenna.
Or.
http://www.antennacraft.net , HBU11K antenna.
Or.
Antennas Direct , Clear Stream CS2V , UHF/VHF antenna.
In/at a South Window or Above the Roof.
Aim the antenna at about 170 degree magnetic compass.
Here is how to aim outdoor and indoor antennas.
Or.
Put a Terk HDTVi antenna (not a HDTVa antenna) in/at the South Window and aim the HDTVi antenna at about 170 degree magnetic compass direction.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
http://www.antennacraft.net.
http://www.amazon.com.
