Old 10-Mar-2014, 2:17 AM   #3
joshg0207
**http://www.tvfool.com/?option=com_wr...5b94e62254e8fa
I have two setups right now a temporary one and a permanent one...I cant use the permanent one cause the rotator dont work...but its a channelmaster 3020 antenna on a 40ft tower with a channelmaster 7777 preamp and a rotator...the one im testing right now is ge attic antenna on a pole with a rotator on the outside of the house about 30 ft in the air...I first used a electroline drop amp and was able to pick up wtaj with 50% signal strength and watm with about 30% signal strength but it had drop outs...so I got a channelmaster 7777 pre amp and hooked it up and thought I could fix the dropouts on watm but the signal strength was worse with the channelmaster preamp about 30% on wtaj and no signal on watm...was just wondering why the channelmaster isnt performing better than the electroline drop amp any idieas...
joshg0207 is offline   Reply With Quote
