Old 9-Mar-2014, 6:18 PM   #1
pgoodiso
Cut the Cable, looking for some Antenna advice
So I have cut the cable/satellite dependency and want to get as many free-to-air channels as possible (will make for a happy family!)
I ran the tvfool report: http://www.tvfool.com/?option=com_wr...5b9413e14ed79a and it looks like I have two transmitters that are within range (almost 140 degrees apart). So I'd like advice as to the type of antenna I should go for. I was thinking about the Antennas Direct, inc DB8e so I could point at both transmitters, but don't really know if this is a good idea. The intent is to mount the antenna on the old satellite mount outside.
I only need to feed one TV and will be using the coax that the satellite dish used. I will be purchasing a digital tuner as my TV does not have a digital tuner (any advice on tuner boxes would also be appreciated).
Thanks in advance for any advice.
pgoodiso is offline   Reply With Quote
