Old 9-Mar-2014, 11:51 AM   #1
Smash74
Antenna config for NEPA
Hey guys, check out my analysis...
http://www.tvfool.com/?option=com_wr...5b94c555ce67d2
As you can see I have stations in all 4 directions, and they're a mix of UHF and VHF so I'm not quite sure how to design a setup. It looks like I will need more than 1 antenna and at least 1 combiner. I am going to mount about 80 to 100 ft above the ground on my chimney with little to no obstructions.
I would very much appreciate suggestions and advice for antennas and setup. I have heard good things about the 91xg for long range UHF...other than that, I'd like to hear your opinions. I'm planning on using 2 or maybe 3 tvs, with the longest cable run being about 120 ft roughly.
Smash74 is offline   Reply With Quote
