Old 8-Mar-2014, 4:05 PM   #3
The Winegard HD7694P and Antenna Craft HBU33 , will most likely not be found on any of the islands and shipping costs from the main land are very high.
The Tvfool report is showing the Tv stations are in the Green and Yellow reception zones and are LOS=Line Of Sight , the best type and kind of reception because their are no natural land obstructions between the transmitting antenna and receiving antenna.
Best Buy stores have the Antennas Direct , Clear Stream CS2V , C2-V-CJM antenna.
Aim the antenna at about 290 degree magnetic compass direction.
Install the antenna Above The Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , West and North West.
A antenna system amplifier will most likely not be required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions in the directions of reception including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location the has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv Stations/Channels.
And the Tvfool report is also showing , Analog Broadcast Tv Stations/Channels.
In the Tv Setup Menu , look for a full channel scan , selection/option , so the Tv will scan for , digital and analog broadcast Tv stations channels
Do Not channel scan for Analog Tv channels only.
And Do Not channel scan for cable Tv channels.
Last edited by teleview; 9-Mar-2014 at 6:58 AM. Reason: Clarify information and typos.
