[QUOTE=  Your situation is one that calls for "walking the roof", meaning, moving the antenna up/down and laterally to find a "sweet spot" were the desired signal is strong and the interfering signal is weak. [/QUOTE]
I tried that in the attic with limited success.  Though trying to maneuver an 8' antenna through the trusses and not step through the ceiling accidentally really limited my options.
I've looked at the other sites you provided, even got a channel 13 only filter, but apparently the old VHF antenna I'm using for that is also helping with channels 3 and 8 from the south so I can't use the filter.  Unless maybe a third antenna.  Yeah, that's the ticket...
