Old 7-Mar-2014, 12:41 AM   #5
I called the engineering department at KTVL , Yes the VHF channel low band channel 4 , K04JQ repeater transmitter for KTVL channel 10 , is on the air.
http://en.wikipedia.org wiki/KTVL.
The Tvfool radar report and channel list shows only Real VHF channels , 4 , 5 , 8 , 12 , 10.
No UHF channel 14 thru 51 , at your reception location.
So a VHF channels 2 thru 13 antenna will receive the Digital Tv Station/Channels.
I say give this Smaller Antenna a Test , the price is Low Dollars.
http://www.antennacraft.net.
CS600 VHF channels 2 thru 13 antenna.
Also install a , 10G221 preamplifier.
Connect the CS600 to the VHF connection of the preamplifier and operate the preamplifier in the , Separate VHF/UHF antennas mode or the combined antenna mode.
Tvfool shows no current UHF Tv stations/Channels.
So when UHF channels begin transmitting the 10G221 preamplifier has the separate connection for a UHF antenna.
http://www.ronard.com/9809911.html.
Use the , ronard(4560) eave antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence , PIPE , that make excellent antenna mast pipe , the price is about 10 dollars.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are the Tv stations.
http://en.wikipedia.org/wiki/KTVL.
http://en.wikipedia.org/wiki/KOBI.
http://en.wikipedia.org/wiki/Souther...lic_Television .
http://en.wikipedia.org/wiki/KDRV.
Last edited by teleview; 9-Mar-2014 at 5:55 AM. Reason: Clarify information and typos.
