Old 6-Mar-2014, 11:21 PM   #4
OTA_newb
I just thought it might be worth mentioning that the antenna I'm currently using is very similar to the model suggested. The only difference being that the end with the long skinny poles is split into 2 masts that are angled apart from each other. I'm assuming this is an outdated model because I can't find anything like it online. But I'm wondering if there's anything I can do to make it work a little better? Maybe take one of the masts off and make the other parallel to the ground like the HD1850? Or maybe put them as close together as possible rather than the ~45 degree angle they're currently at? Like I said, I get 12.1 clearly with it, and got 5.1 for a while, so I'm sure it's not far from picking up a few of the channels on the list.
OTA_newb is offline   Reply With Quote
