Old 5-Mar-2014, 10:52 PM   #6
A second antenna system will provide several Canada Tv Stations/Channels.
Install a Winegard HD7084P antenna aimed at about 10 degree magnetic compass direction.
Install a Antennas Direct , PA-18 , preamplifier.
This second antenna system Is Not connected to the USA antenna system.
At each Tv location a Remote control A/B antenna switch is used to change antenna systems.
http://www.mcmelectronics.com.
Model Number 32-4425 .
Or use No A/B switch.
Use a Separate Tuner/Recorder connected to the USA or Canada antenna system.
http://www.epvision.com.
As a Test of Canada Tv stations reception.
The HD7698P antenna can be aimed at the Canada Tv Stations to the North at about 10 degree magnetic compass direction.
And scan for channels.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence PIPE , makes good antenna mast pipe.
Cost is 10 dollars.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
The USA and Canada antenna systems are Completely Separate antenna systems.
Last edited by teleview; 6-Mar-2014 at 4:57 AM. Reason: Clarify information and typos.
