Old 5-Mar-2014, 1:21 AM   #6
stvcmty
Originally Posted by ravendragonwing View Post
no way to then connect to TV
I have used "flat" coax to go in sliding doors. They are white jumpers 6 to 8" long with female F connectors at each end. If the door is not opened much, they work good enough.
If your porch has good signal, putting and antenna out there and running coax to the TV will be much more rewarding than playing with an indoor antenna.
That being said, an indoor antenna could work if you get the right combination of signal, lack of multi path, luck, and location.
What indoor antenna did you try? Does it have an amplifier?
stvcmty is offline   Reply With Quote
