Old 4-Mar-2014, 8:05 PM   #3
-->Many<--USA Digital Broadcast Tv Stations/Channels Will Be Received.
For reception that Also includes , Canada Tv Station/Channel , CBET-DT Real VHF high band channel 9 , The CBC.
Above the Peak Of The Roof install a , http://www.antennacraft.net.
Also buy the Y10-7-13 antenna at , http://www.amazon.com.
Y10-7-13 , VHF high band channels 7 thru 13 antenna is aimed at about 90 degree magnetic compass direction.
The Y10-7-13 antenna is Also for reception of.
WJBK Real VHF high band channel 7 , FOX and Movies.
WILX-TV Real VHF high band channel 10 , NBC and Antenna Tv.
The other -->Many<-- Tv Stations/Channels are UHF Tv channels.
Also install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim 1 panel at the ~East North East~ Group of Tv stations at about 80 degree magnetic compass direction.
Aim the other panel at the ~North West~ Group of Tv stations at about 300 degree magnetic compass direction.
Install a , http://www.antennacraft.net.
10G221 preamplifier.
Also buy the 10G221 preamp at , http://www.amazon.com.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
Connect the DB8e antenna to the UHF connection of the preamp.
Operate the preamp in the separate antenna mode.
The FM radio trap will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 feet 6 inch lengths of , TOP RAIL , chain link fence PIPE that makes good antenna mast , the price is low dollars about 10 dollars.
As always . trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , ~East North East~ , ~North West~.
Go into the Tv Setup Menu and select.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the TV Setup Menu.
In the Tv Setup Menu.
DO NOT select and channel scan for cable tv channels.
If you have any type or kind of cable delivered service such as , cable tv service , cable internet service , cable phone service , the cable delivered services Must Be on a Separate Coax that is not connected to the coaxes that are used for the antenna system.
Yes the cable coaxes can be used for the antenna system , but any cable delivered service must be on a Separate coax not connected to the antenna system coaxes.
If you no longer have satellite service the coaxes that were used for the satellite system can be used for the antenna system.
Disconnect and remove all satellite system componets such as and not limited to , receivers , multi-switches , multi-plexers , splitters , couplers , amplifiers , power injectors/power supplies and etc. .
Many people are going with the internet streaming services such as and not limited to , Netflix , HULU+ and etc. .
The December 2013 issue , page 42 , of Consumer Reports , has a Practical and Useful article about receivers and services.
Last edited by teleview; 5-Mar-2014 at 3:30 PM. Reason: Clarify information and typos.
