Old 4-Mar-2014, 6:10 PM   #4
Thanks for the second TVFR...
Conditions do improve as you go up. However, given the added expense and complexity of mounting at 50', I'd try at a lower level that is easier to access. If the need is proven, you can always add a guyed push-up mast.
Consider the Winegard HD7698P pointed south. An Antennas Direct PA-18 preamplifier would be indicated as well.
