Testing with an inexpensive antenna is certainly a prudent way to start. Consider the RCA ANT-111, which I see offered online for under $9 at the moment.
Connect it to the TV, then use the setup menu to switch the TV from cable mode to 'air' or 'antenna'. You'll also need to run a scan for channels. Based on your report, I'd expect you to see at least one signal... But likely more.
If I was in the same situation, I'd use an Antennacraft HBU-44 pointed at about 80° (compass). If there are several TVs to connect, I'd also install an RCA TVPRAMP1R preamplifier.
