The ANT-751 and HBU-11 are less antenna than what I would be comfortable recommending. Antennas such as the Winegard HD7694P and Antennacraft HBU-33 are more suited to the modest signal levels at your location.
Alternately, you could consider an Antennas Direct DB4E + CS5. They not nearly as long as the classic Yagi type antennas, but offer comparable performance.
Experiment with mounting location, use what works.
