Do the best you can in the attic.
Move the antenna to different locations.
Often , better reception happens with the antenna up high in the attic.
Also avoid metal and duct work and electric wiring , and some attics have metal backed insulation , avoid obstructions to reception in the directions of reception as much as possible.
And adjust the antenna aim.
Most Digital Tv's have Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Signal Quality is Important for Reliable Reception.
The less obstructions to reception in the directions of reception , the better the signal quality will be.
