Old 4-Mar-2014, 12:13 AM   #11
Originally Posted by brg88tx View Post
trying to get an idea of how much an attic install affects signal strength......all else equal would I be better off with a winegard hd 7698p in the attic or a clearstream 2-v out on the roof?
I have a huge attic and have the room, but I do have tech shield foil on my roof decking. thanks
Attics are a huge variable... The only way to know what your attic is like, is to put an antenna up there and see what you get. It's entirely possible that you could have the worst attic in the state, and not even the 7698 would work. On the other hand, your attic may be fine and you could use the CS2-V and be delighted with the performance.
