Old 3-Mar-2014, 10:22 PM   #7
A satellite view of the Area shows that Many of the houses are Directly In large stands of thick dense trees.
So I ask about your location , about the trees.
Trees and and tree leaves are Not Friendly to Tv reception.
Trees and tree leaves , Absorb and Block and Reflect Tv reception.
The higher antenna height tvfool reports so little to no increase in signal strengths of the weak signal strength tv stations in the Red reception zone of the tvfool reports.
So what is Very Important at your reception location is to get the antenna Up High to clear the trees as much as possible.
Above the Peak of the Roof install a , http://www.antennacraft.net.
HBU44 antenna aimed at about 216 degree magnetic compass direction.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
Operate the 10G201 preamp in the combined antenna mode.
The FM radio trap switch of the 10G201 preamplifier will be in the , in/on position.
Buy the , HBU44 antenna and 10G201 preamplifier at , http://www.antennacraft.net , or , http://www.amazon.com.
Recommend for initial reception Test have only 1 Tv connected , No splitters.
WFSB , CBS.
WTIC-Tv , FOX and Antenna Tv.
WCCT-Tv , CW and This Tv.
are Very weak signal strength in the Red reception zone of the tvfool report.
So is important to get the antenna Up High to clear the trees as much as possible.
To that end , here are some above the roof antenna mounts.
Use the , ronard(911), 5 foot tripod antenna mount.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot and Lowes have 10 foot 6 inch lengths of , TOP RAIL , chain link fence Pipe that makes good antenna mast , the price is about 10 dollars.
Last edited by teleview; 4-Mar-2014 at 4:47 PM. Reason: Clarify information and typos.
