Thread: HDX1000 vs DB4e
Old 3-Mar-2014, 9:00 PM   #9
dmfdmf
Originally Posted by Orion0485 View Post
...I estimate another 50' run of coax in wall to get to the TV.
If this is a prewired home you might want to check where that wire goes. Ideally it should be a straight shot to the TV you are trying to feed. Sometimes these in-wall coax runs snake all over the house if there are TV ports in other rooms they probably also have a -3 dB splitter or tap at each location. See if you can find the path and then remove any taps/splitters at each TV outlet and replace them with straight through couplers. Read the wire and see if it is RG/59 or RG/6 in the wall.
dmfdmf is offline   Reply With Quote
