Thread: HDX1000 vs DB4e
Old 3-Mar-2014, 7:28 PM   #8
dmfdmf
Originally Posted by Orion0485 View Post
I am not sure how to bypass the amp.
It may not be possible, from the description it is a built-in pre-amp.
I am driving one TV currently on the first floor. I have a long coax run from the antenna to the TV since the antenna is on the roof of the second floor and the TV is on the first. Furthermore, the power inserter for the antenna is at the end of a 50' coax run (from antenna to power supply in attic). Unfortunately this is as close as I can get the power inserter.
That should work fine.
From the inital 50' coax run, I estimate another 50' run of coax in wall to get to the TV. I have installed a Radioshack 12db gain in-line amplifier right after the antenna power inserter to help overcome the loss in the last 50' of coax.
So you have two amps? I'd try it without that second amp. Your TV Fool report indicates that you have plenty of signal in the "air" and the pre-amp is adding 10 db with 2.5 db loss factor at the antenna so this should work with one TV. It should look like this;
<Ant. w/ pre-amp><50ftCoax><Pwr Injector><50ftCoax>TV
Are these 50ft continuous runs of coax RG/6 or is it piecemeal RG59 with any splitters, couplers in there other than the power injector?
My inital install pointed the antenna at magnetic north, but after that I used the TV's (Sharp Aquos) signal meter to tune the channels in. For the most part I get good reception on 46.1, but it becomes unwatchable later in the night (8-9pm).
This seems like an atmosphere issue. Fox is 1Edge so I think moving the antenna around will help. If you could move it higher that would probably work the best. Alternatively, as a test can you tilt it up a bit, above horizontal, instead of changing the azimuth. Sometimes that helps with 1 or 2Edge stations but I think you might need to raise it a few feet, you are probably right in a refracted dead zone that changes at night.
There are also some PBS channels that I get poor reception (42.1/2/3 for example)
42.1 is a virtual channel number, its real channel is RCH11. This is important because RCH11 is a VHF station and from the looks of it that antenna probably doesn't have much gain at the lower frequencies. However, you should be getting a strong connection to PBS from WNSC on VCH30/RCH15, so its probably not worth changing out the antenna to improve signals on duplicate stations. If you wanted get 42.1 reliably you would probably have to get a different antenna.
dmfdmf is offline   Reply With Quote
