Old 3-Mar-2014, 6:57 PM   #8
StephanieS
Hi Lee,
The easiest thing to do at this point is test a few different directions to see if you get what you want. It depends if ION is something you want or if you are satisfied with just the major networks. If so, try a heading of about 220. Is Ion reliable at your current heading?
If that doesn't yield results move the antenna physically a few feet in another direction and retest in the attic. You may find a "sweet spot" Attics are notorious for signal problems, multi-path and interference.
If that doesn't work, mount outside with the clear pathway either to 220 or 120 and rescan.
SS
