Old 3-Mar-2014, 5:33 PM   #2
For reception of as many Digital Broadcast Tv Stations/Channels as possible in the directions of , West , South West , South , South East , East.
With 1 antenna aimed in 1 direction.
At 30 feet antenna height or higher above ground.
Install a , http://www.antennacraft.net ,
HD1800 All channel antenna.
10G201 preamplifier.
The 10G201 preamplifier will be operated in the combined antenna mode.
The FM radio trap switch of the 10G201 preamplifier will be in the in/on position.
Aim the , HD1800 antenna at about 227 degree magnetic compass direction.
Use a real and Actual magnetic compass to aim antenna.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roofs and buildings.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HD1800 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roofs and buildings.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com
To fine tune antenna aim and aim antenna at Tv stations that are not received with antenna aimed at about 227 degree magnetic compass direction.
Install a , www.nteinc.com/antenna-rotors.php?a=28.
However Know this about antenna rotation.
Antenna rotation Is Not channel surfing friendly , must wait for antenna to rotate.
Antenna rotation Is Not recording friendly.
And their Will Be Domestic Situations about the direction the antenna is aimed.
To Discover What Digital Broadcast Tv Stations/Channels Are Received with the HD1800 antenna aimed at the 227 degree magnetic compass direction.
Install the antenna system.
DO NOT connect the HD1800 antenna to any other type or kind of antenna.
DO NOT connect the above described and recommended antenna system to any other antenna or antenna system.
Last edited by teleview; 4-Mar-2014 at 5:10 AM. Reason: Clarify information and typos.
