northernly direction from your location.
I would use a 2 antenna system for you, consisting of an AntennasDirect XG-91 UHF antenna aimed at Needham for the Boston stations, and an AntennaCraft Y-5-7-13 5 element high-band VHF yagi aimed at Manchester for channel 9. I would combine the signals using an Antennacraft 10G221 high-input preamplifier, then run the output of the preamp power supply to to your TV set(s):you'll see all of the major Boston stations plus manchester and Derry without any problem at all.
