Old 3-Mar-2014, 5:15 AM   #4
If the roof is a metal roof the signal will be reduced and blocked.
Up High in the vaulted ceiling install a , http://www.antennacraft.com ,
HBU11k antenna aimed at about 100 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
