Thread: Antenna Help #2
Old 3-Mar-2014, 2:30 AM   #3
Reception is good at the 20 feet antenna height.
Install a , http://www.antennacraft.net ,
HBU44 antenna aimed at about 250 degree magnetic compass direction , a in between aim direction , for the reception of , KRUS-TV Real UHF channel 35 , http://en.wikipedia.org/wiki/KRUS-TV.
And the main group of Digital Broadcast Tv Stations to the South West.
Here are some Strong Heavy Duty High Quality antenna mounts.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
For 1 Tv connected.
A antenna system amplifier will most likely not be required for the Reception of.
KTUL Real VHF high band channel 10 , ABC and RTV.
KOTV-DM/DT Real UHF channel 45 , CBS and CW.
KOED-TV Real VHF high band channel 11 , PBS.
KOKI-DT Real UHF channel 22 , FOX and Me-Tv.
KJRH-DT Real VHF high band channel 8 , NBC
KMYT-TV Real UHF channel 42 , MyNetwork and Zuus Country.
If the following Weak Signal Strength Tv stations receptions are not reliable and you will like to receive them then install a , http://www.antennacraft.net , 10G201 preamplifier.
KRUS-TV Real UHF channel 35 , Independent Educational Tv.
KHWB-DT Real UHF channel 47 , Religion.
KQCW-DT , aka , KWBT-TV Real UHF channel 20 . CW and This Tv.
Buy the , HBU44 antenna and 10G201 Preamp at , http://www.antennacraft.net , or , http://www.amazon.com.
If 2 or more Tv's are connected then install the preamp.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
AS always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The directions of reception at your location are , West and South West.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select ~ Antenna Channewls ~ ATSC CHannels ~ DTV Channels ~ Air Channels ~.
Channel scan for the ATSC-Digital Broadcast Tv Stations/Channels.
